Can I create 2D Elevation views?
While there is no particular function for creating 2D elevation views, there is a way to get very close to the desired result.
Simply fly to a high position above your project, and, while looking down, adjust your field of view in the General Enscape settings to the left. This way, you can achieve an almost parallel view easily.
Alternatively, you can make use of the Orthographic view projection as seen in our blog post here.
Was this article helpful?
0 out of 0 found this helpful
