How is the free anima® LITE version limited?
Anima® LITE is a free application designed to allow everyone to fully experience and test the latest version of the main tool for 3D scene population and animation: Anima® ALL.
The LITE version will allow you to use the software and decide if it meets your needs. The 2 main differences in functionality are that the Lite version has access to a limited number of models and has important render limitations.
The assets included in the LITE version are the following:
  • 5 4D models
  • 2 4D walking models
  • 29 Rigged actors (compatible with mocap animations)
  • 4 Ready Posed actors (high-detail static models)
  • 13 Ambient actors (high-detail idle animated)
  • 48 Motion Capture files with parametric variations for realistic animations.
The render limitations on the LITE are described below:
  1. You can render 5 different default animated actors for each scene.
  2. You can render 1 different custom-imported animated actor for each scene.
  3. You can render 4 seconds of animation (100 frames at 25 fps).
  4. You cannot render an Anima® LITE scene in an online Render Farm service.
You can use our Drag and Drop panel inside your 3D application just by having Anima® Lite installed. See how this panel works in our video tutorials here.
Like Anima® ALL, the Lite version has all the tools to create traffic lights, squares, and obstacle areas that characters avoid navigating around objects. Walkway tools for walking, running, and locomotion animations with advanced settings for distribution, spacing, direction, clustering, and changing path width at any point.
It also includes all the native connection plugins to synchronize the scenes with Autodesk 3ds Max®, Autodesk Maya®Maxon Cinema 4D®, and Epic Unreal Engine®, plus a lot of Demo scenes for a quick approach to the software.
You can download it here in the following links:
Was this article helpful?
0 out of 1 found this helpful
