Are there Floating Licenses available for anima®?
Anima ALL uses floating seats that can be pre-authorized on multiple devices.
You get 4 devices per seat, and you can manage them from your own user account, in the subscription admin panel. As the activation of the subscription seats is managed by our servers directly, they are totally independent of the physical location of the devices. To start using anima® on one of your devices, you just need to have the software installed and the device pre-authorized, then the software will automatically get the seat from our servers.
For example, with a single seat, you can use anima® in your workstation at your office, then go on a meeting in a different location with a client and use it on your laptop, and then go home and start applying modifications right away using your home PC. The seat will float seamlessly from one device to the next one as long as it is used on one unique device at a time.
You can use each seat of the subscription service (anima ALL) on all the devices available on your account. However, keep in mind that each seat can be used only on one device at the same time. The list of devices can be managed directly by the user, from the subscription admin panel of your account. However, as you can add or remove devices whenever you need to, you can virtually add infinite devices because that is only the maximum number of devices that can be stored in your subscription account at the same time.
All the license management is made through our servers so, please, keep in mind that you will need to have an internet connection in order to use anima® ALL.
To learn more about the subscription, please take a look at the following documentation:
On the other hand, anima PRO does not support floating licenses. Each PRO license is linked to the hardware, so every time you need to move anima® PRO to a new computer, you first need to reset the license to erase the hardware ID link and then you can activate it again in another computer.
For security reasons, this process can only be done once per day and up to 3 times per year. Of course, we will help you if something unexpected happens that occasionally makes you exceed that limit, but that is the main rule.
To learn more about the licensing process or license migration, please refer to the following documentation:
Was this article helpful?
0 out of 0 found this helpful
