Is the Render Node installation mode compatible anima® ALL?
Yes. You can use the Render Node installation mode to render scenes that include subscription models from anima ALL.
The anima Render Node application is fully compatible with anima ALL, so it can render both types of actors, the ones from the subscription, and the ones that you may have purchased already or imported as custom models.
Also, notice that all the devices included in your subscription service (4 per seat) can also be used to render scenes, so in a way, you are effectively getting 3 extra render nodes for each subscription seat (1 seat + 3 nodes = 4 devices).
Please read the documentation linked below to understand how it works:
Mixed-use scenario
As it is not possible to install the anima in Workstation mode and in Render Node mode at the same time in the same machine, this "node mode" state of the devices becomes especially useful in situations where the devices are used alternatively for both the creation and edition of anima content and also for rendering as nodes in conjunction with a bigger render node pool.
Important Update:
As of August 1, 2024, with the release of anima 5.6.0, anima Render Node installations no longer require a license and are free for everyone to use.
However, the older versions of anima (5.5.0 and older) still require the use of a Render Node license. More information about the legacy Render Node licensing process can be found in the following documentation: Licensing Render Nodes.
Was this article helpful?
0 out of 0 found this helpful
