Is it possible to use subscription models with the Anima PRO license?
If you try to create or edit scenes created with Anima ALL, the models downloaded from the subscription service will not be recognized as valid when using the PRO license. They will appear as blocked actors in the library (with a lock icon overlaid) when using the Anima Designer standalone application or the AnimaDrop panel from the plugins.
However, scenes with anima content including subscription models can be loaded through the anima plugins (on a DCC app) and rendered without issues.
Was this article helpful?
0 out of 0 found this helpful
