What are the additional components which Corona needs to work and how to install them?
What are the additional components?
The additional components include Microsoft Visual C++ Redistributable Packages, which are required to run any C++ application built using Microsoft Visual Studio (such as Corona Renderer, Corona Standalone, Corona Image Editor, but also other software). These components come as small files - either a standalone installer, or as a Windows Update package. and are provided by Microsoft for free.
Do I need to install those components manually?
No. By default, our Universal Installer will install all the required components automatically. You may however need to install them manually in some situations, such as using the "unpack files" option in the installer, or if the automatic installation fails for some reason.
Which version to use?
- For Corona Renderer 2 and newer - Microsoft Visual C++ Redistributable for Visual Studio 2017 x64
Where to download them?
The components can be downloaded from the following Microsoft websites:
https://support.microsoft.com/en-gb/help/2977003/the-latest-supported-visual-c-downloads
Note: always download the x64 version!
or
https://visualstudio.microsoft.com/downloads/
Is there a silent mode for installation?
Yes. Run the installer from Elevated Command Prompt (type "cmd" into the Windows search, right-click on "Command Prompt", select "Run as Administrator") and use the following switches: /install /quiet /norestart
In case of troubles with locating or installing the required files, please contact us.
