This message appears if during rendering there is a change made to a bitmap file used in a standard 3ds Max Bitmap node. A typical case is modifying a texture in a 2D application and saving it while Corona is rendering. When this error message is displayed the rendering is stopped (to prevent crashes or other problems) and has to be restarted manually.
This message is never displayed when using interactive rendering (in such case the rendering will be automatically restarted instead).
Solutions:
- Use Corona Bitmap node instead of standard 3ds Max Bitmap
You can convert all 3ds Max bitmaps to Corona Bitmaps with a single click using the Corona converter script. - Enable the "Lock 3dsmax during render" option in Render Setup > System > System Settings > System settings.
