Chaos
Do I need a processor with SSE 4.1 to run Corona?
Up to Corona Renderer 1.7 hotfix 2 - no, you can also use a processor without SSE 4.1 and Corona Renderer will run the Legacy version which is about 20% slower.
From Corona Renderer 2 onward - the legacy version is no longer offered and you need a CPU that supports the SSE4.1 instruction set (that is, any processor from within the last ~10 years). Here is a list of compatible CPUs
From Corona Renderer 3 onward, the Licensing Server and the DR Server no longer support CPUs without the SSE4.1 instruction set and are now 64-bit only applications (they will not run on 32-bit versions of Windows).
If you wish to run Corona on a CPU which does not support SSE 4.1, you can download Corona Renderer 1.7 or older here: https://corona-renderer.com/download/old
Was this article helpful?
0 out of 0 found this helpful
