These messages are triggered when the UHD Cache file or its location cannot be reached or modified.
1. Cannot load UHD Cache from a file. The new cache will be calculated from scratch.
If the UHD Cache file cannot be loaded, a new one will be calculated from scratch.
Possible causes:
- The cache file was moved or deleted
- The cache file path is pointing to a non-existent location
- The file was stored on a removable device/network location which is unavailable now
- The cache file path is pointing to a location to which the user does not have appropriate write/modify permissions
Solutions:
- Make sure the cache file is present in the entered file path
- Make sure the cache file is not used by any other computers/users
- Make sure the entered cache file path is reachable and can be read
2. Cannot save UHD Cache to file.
This message means that a problem was encountered while attempting to save to cache file.
Possible causes:
- The cache file path is pointing to a removable device/network location which is unavailable now
Solutions:
- Make sure file is not used by any other computers/users
- Make sure the entered file path is reachable and can be written in/modified
3. Cache saved with an old version of Corona won't load in a newer one.
Loading caches generated in older versions with newer versions of Corona is not supported.
Solutions:
- Save a new Cache with the new/currently installed Corona version.
