How to disable full VFB refreshing when using region rendering?
By default, VFB will be cleared once the rendering begins. This is sometimes unwanted (for example when re-rendering a part of the image using region rendering).
To disable the VFB refreshing use the "Clear VFB in between renders" option under Render Setup > System > Frame Buffer.
