Does Corona support network rendering?
Yes, it does. You can render over the network using Autodesk Backburner, 3rd paty render managers, or use Corona's integrated DR solution (3ds Max only).
See:
- 3ds Max: How to use Distributed Rendering?
- Cinema 4D: How to use Team Render (Distributed Rendering in C4D)?
Important note: Corona's native Distributed Rendering should be used mainly in cases where multiple computers are rendering a single image (the process is described below in this guide). If you need to render a sequence of frames, where each single computer is rendering a different frame, it is advised to use other network rendering solutions instead such as Autodesk Backburner or 3rd party render manager applications.
