How to use the Corona Standalone?
The Corona Standalone is intended mainly for use by power users and 3rd party plugin developers with special exporters. It does not come in a "studio" version with a graphic interface exposed. All Corona Renderer properties from the host application can be exported into it, and developers of exporters have access to all features.
If you want to create a scene in some 3D application that does not have a Corona Renderer plugin yet, and you want to render that scene using Corona Standalone, then the only option available for now is first to import the model to another supported application (e.g., 3ds Max or Cinema 4D), or to create an exporter script that saves the model, lights and materials as an OBJ file.
Currently, some of the advantages of using Corona Standalone include:
- Possibility to render 3D scenes without other 3D software (e.g., on a computer without C4D installed)
- Lower RAM usage - Corona Standalone will use less RAM than Cinema 4D
For additional information on Corona Standalone, see:
Corona Standalone - Corona Renderer wiki
Simple Guide
Note: This example requires having C4D installed!
If you're using Corona Renderer 7 and above:
By default, the Corona Standalone will be installed into:
-Corona Renderer (windows): C:\Program Files\Corona Renderer for Cinema 4D\Standalone\ and the executable name is Corona.exe
NOTE: Currently, macOS is not supported.
Start Cinema 4D and prepare your scene for rendering.
Once you're ready to render your scene:
In Cinema 4D, go to the menu File > Export... > Corona Standalone (*.cdo).
Then select the location where the scene file should be exported.
This will export the current scene into a .cdo file format
Next, launch the Corona Standalone application (you can also place a shortcut to the Standalone on the Desktop or in the Start menu to access the app easily)
When launched, the application will show a dialog asking for the scene to be rendered - select your .cdo file, and it will start rendering immediately.
If you're using Corona Renderer 6 or previous:
Install the Corona Standalone included in Corona Renderer 6 or previous), which is available in an installer of a previous version
In Cinema 4D, go to the Render Settings > Performance > Development / Experimental Stuff and press Export .cdo file, then select the location where the scene file should be exported.
- Next, launch the Corona Standalone application (you can also place a shortcut to the Standalone on the Desktop or in the Start menu to access the app easily)
See also:
