How to report issues to Chaos support?
If you encounter an issue and you are not able to solve it by yourself, the best idea is to contact us.
A properly prepared report will be easier to understand for our team and will also guarantee that the problem is fixed as quickly as possible. A chaotic, vague description will usually bring the opposite effects - it will be hard to understand for our support team and developers, and analyzing it will require additional time and effort.
Below you can find simple guidelines on how to provide the Chaos support team with easy to understand reports, so that your issue is resolved as quickly as possible:
Was this article helpful?
2 out of 9 found this helpful
