I am an Enscape user, why do I need the compatibility?
  1. This new compatibility gives you the ability to coordinate the designs you visualize with Enscape directly with V-Ray artists without any additional effort, so you can increase the quality and detail of your visualizations whenever you need to.
  2. You can offer your clients the immersive experience of the design in Enscape and render the same project with higher quality to attract more clients and advertise your work.
  3. When both tools are used within your company, a seamless Enscape to V-Ray workflow can be established between the design and high-end visualization phases of the same project. This helps the team save time and ensures a smoother hand-over from the designer / architect who uses Enscape for planning purposes to the visualizer who is working on the high quality visualization. There is no need to start everything from scratch and things like materials and assets originated in Enscape can be used as a starting point.
  4. The planner / architect will be able to set a certain direction for the visualization professional. E.g. the choice of vegetation assets, sun position and materials will be helpful for the visualizer to understand the planners' intent. More assets can be added from Cosmos right at the end, to add more variety and dynamism.
  5. Cost savings for architectural firms commissioning external studios for photorealistic image creation that are working with V-Ray: no need to pay for setting the model up from scratch.
  6. For visualizers who use both products already, the decision which software to use is now easier as they don’t have to start from scratch when switching from Enscape to V-Ray.
Was this article helpful?
2 out of 3 found this helpful
