Chaos
Back to Chaos website
Contact Support
Sign in Try Buy
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
  1. Chaos Help Center
  2. FAQ
  3. Suites
  4. Licensing
Can I switch my named license for a floating license?
Updated May 20, 2025 06:00
You can upgrade your named license to a floating one based on the upgrade options available to you. You can check what upgrade options you have in the my.chaos portal under “Products”.
Was this article helpful?
0 out of 1 found this helpful
Articles in this section
  • Which software versions can I use with the suite product offerings?
  • What is a named license?
  • What licenses do Chaos products use?
  • What is the difference between named licenses and legacy Fixed/Solo licenses?
  • What is the difference between named and floating licenses?
  • What versions of Chaos products can I use?
  • Can I use my named license anywhere?
  • I have two devices, do I need to buy two licenses?
  • Can I share my named license with a colleague?
  • I currently have an Enscape Fixed license. What will happen to it?
See more
