Render fails or server errors
If your Veras render fails with a server or syntax error, try the steps below to resolve it.
Common issues include:
  • Syntax errors in the log (e.g., SyntaxError: Unexpected token)
  • “Veras render service error”
  • “Internal Server Error”
To fix this:
  1. Confirm which authoring software you're using (e.g., SketchUp, Revit).
  2. Check that the Autosave folder path exists and is accessible.
  3. Try disabling Autosave as a test.
  4. Server outages are rare, but let us know if the issue continues.
Was this article helpful?
0 out of 9 found this helpful
