I am getting "failed to initialize" error message for Corona plugin files at 3ds Max startup
This guide applies in cases where 3ds Max displays a "failed to initialize" error message at startup for one or more Corona plugin files. An example error message reads:
DLL <C:\Program Files\Autodesk\3ds Max 2024\Plugins\CoronaMaxUtils2024.dlt> failed to initialize properly – not loading.
Solutions:
If the problem persists, try the following:
  1. Press the Windows Key + R to bring up the "Run" window
  2. Type sysdm.cpl and press Enter to open the System Properties window
  3. In the System Properties window, go to the Advanced tab
  4. Click "Environment Variables..."
  5. Click "New..." under "System Variables"
  6. Enter the following variable name:
    CORONA_3DSMAX_2026_LOAD_PATH
    Note: adjust the path accordingly depending on your 3ds Max version. For example, in case of 3ds Max 2024, that would be CORONA_3DSMAX_2024_LOAD_PATH.
  7. Enter the following variable value:
    C:\Program Files\Chaos\Corona\Corona Renderer for 3ds Max\2026
    Note: adjust the value accordingly depending on your 3ds Max version. For example, in case of 3ds Max 2024, that would be C:\Program Files\Chaos\Corona\Corona Renderer for 3ds Max\2024.
  8. Press OK to save the variable and its value
  9. Press OK to close the Environment Variables window
  10. Press OK to close the System Properties window
  11. Check if 3ds Max starts up normally and whether Corona is available on the list of renderers in the Render Setup window
To learn more about using environment variables with Corona, see Multiloaders at the Chaos Documentation Portal.
Was this article helpful?
0 out of 5 found this helpful
