What can Chaos Vantage be used for?
  • Arch-Viz Artists
    • Scene exploration — Interactively explore and present unlimited design variations. Switch between design options, material schemes, and lighting configurations to compare, explain, and explore all the possibilities you have for your design or its presentation.
    • Viewport companion — See every aspect of your scene as you work in your content creation tool. A real-time companion view unaffected by scene size that gives you a highly realistic view of your scene as you adjust materials, lighting, and geometry.
    • Fast-rendering — Super-fast rendering that is better than “good-enough”. Produce high-quality renderings and animations in record time at a quality level that makes approval easy - including all the render elements needed for post-production.
    Visual Effects Professionals
    • Real-time reference — Real-time ray tracing that closely matches your production rendering results as you finalize your scene. It’s perfect for over-the-shoulder discussions while making decisions.
    • Playblasts at much better quality — Playblasts that convey the actual materials and lighting of your production for accurate review and approval sessions.
    Previsualization — Previz with full-size scenes that can be reused in production. Real-time raytracing, without any scene preparation or light baking that uses the same materials and lights as your production team uses.
Was this article helpful?
3 out of 4 found this helpful
