I am getting MAXScript Auto-load Script Error - C:\Program Files... - Known system exception - The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
This guide applies in case you are getting the following error or similar:
-- Known system exception
-- Address: 0xbbf204fa; nCode: 0x00000000C0000005
-- Desc: EXCEPTION_ACCESS_VIOLATION The thread tried to read from or write to a virtual address for which it does not have the appropriate access.
-- Read of Address: 0x0000000000000080
Possible solution:
Set Maxscript initial heap allocation to 256 MB in 3ds Max settings as instructed in the attached screenshots and then restart 3ds Max:
See also: Corona Converter script is not working!
