The right choice depends on your host app, hardware capabilities and speed vs. quality needs. Consider the following points before choosing:
- Define your goal: Decide whether you need real-time feedback for design review or photorealistic final renders for production.
- Confirm your host application: Note whether you work in 3ds Max, Maya, SketchUp, Rhino or another supported platform.
- Assess hardware: Check your CPU/GPU, RAM, and VRAM to determine whether CPU, GPU, or real-time rendering best fits your machine.
- Plan for collaboration: Verify that teammates, pipelines, and file formats are compatible with the renderer you choose.
Validate with trials and sample scenes: Run a short test on your typical project to confirm performance, quality, and ease of use.
Choosing the right Chaos render engine:
Based on hardware
CPU rendering
Both V-Ray and Corona fully utilize your CPU.
If CPU performance is your priority, you can use either V-Ray or Corona to take advantage of your processor’s full potential.
GPU rendering
If you prefer GPU-based workflows, V-Ray is the right choice since Corona does not offer GPU rendering.
Based on host software
- If you use 3ds Max: you can choose either V-Ray or Corona.
- If you use Cinema 4D: you can choose Corona.
If you use Maya, SketchUp, Rhino, Houdini or Blender, only V-Ray supports these platforms.
Based on flexibility
If you want out-of-the-box photorealism with minimal setup, choose Corona; if you need maximum control and per-object customization, choose V-Ray.
Choose Corona for simplicity
Choose Corona if you want high-quality, photorealistic results without adjusting advanced parameters and can accept less flexibility.
- Get photorealistic results out of the box with minimal tweaking.
Focus on simplicity over adjustability. Limited options for non-physical effects, such as disabling shadow casting.
Choose V-Ray for flexibility and control
Use V-Ray when you need photorealistic quality with extensive control over non-physical effects, render settings, and per-object quality.
- Disable shadow casting for selected objects.
- Control object visibility in reflections.
- Exclude objects from environment lighting influence.
- Tweak render settings to meet your needs, including quick draft previews.
Define per-object quality to customize how the render engine treats each object.
Learn more about V-Ray's features.
Based on production type
Both V-Ray and Corona can render stills and animations; choose V-Ray for animation workflows that need granular control, and choose Corona for effortless high‑quality stills.
Rendering stills
For high-quality still images, both V-Ray and Corona work well, with Corona emphasizing minimal setup.
- Corona lets you render high-quality stills with little effort.
- V-Ray also produces excellent stills and gives you advanced control over what you render and how.
Rendering animation
For animations (sequences), V-Ray is generally better optimized because it offers more control over render settings and per-object quality, helping you reduce render times without sacrificing much quality.
- Both V-Ray and Corona can render sequences, but V-Ray’s flexibility makes it a stronger choice for animation.
- Use V-Ray’s detailed controls to balance quality and speed per object and per setting.
V-Ray’s flexibility and advanced controls make it suitable for both stills and sequences.
Based on post-production workflows
For compositing and post-production, choose V-Ray if you rely on render elements and masks in external compositing apps; choose Corona if you prefer straightforward adjustments directly in the VFB.
Choose Corona for simple in‑VFB post‑processing
Corona keeps compositing simple by letting you adjust the image directly in the VFB.
- Modify your render in the Corona VFB with stackable operators you can add, remove, and rearrange.
- Use basic masking render elements for straightforward compositing needs.
- Keep everything in one place for a streamlined, easy-to-manage workflow.
Choose V-Ray for advanced compositing workflows
V-Ray is the better choice when you split renders into render elements, use masks, and finish in external compositing tools.
- Leverage a sophisticated set of render elements to achieve virtually any post-production effect.
- Create pixel-perfect masks and selections for precise isolation and adjustments.
Use advanced V-Ray Frame Buffer (VFB) controls for powerful in-buffer edits before sending to comp.
Based on software complexity
Corona is generally easier for beginners, while V-Ray offers more advanced workflows with a slightly steeper learning curve.
- You can get good-quality results out of the box with Corona.
- With V-Ray, expect a slightly steeper learning curve due to its advanced workflows and extra possibilities.
- You can learn both products with the large collection of available documentation articles and tutorials.
- This article summarizes the industries where V-Ray and Corona are commonly used and links to more resources.
Based on industry
V-Ray
V-Ray is widely used across design and entertainment industries such as Architecture, Interior design, Product design, Automotive, VFX, Advertising, Games, etc.
Corona
Corona is primarily intended for architectural visualization (archviz), but it is also used in related fields such as Interior design, Product design, Automotive, etc.
Learn more about the Corona suitable industries.
Based on hands-on experience
Both V-Ray and Corona can produce high-quality, realistic renders with similar render times. Choose the one that fits your workflow by testing both with your own scenes. The right renderer is the one that feels faster and easier for you on real projects.
- Download the trials: Download the V-Ray free trial and Download the Corona free trial.
- Test with your own scenes to compare image quality and render times under similar conditions.
- Evaluate the experience: consider the user interface, the number of built-in tools, and how quickly you can achieve the results you need.
- Decide which renderer best matches your workflow and requirements.
