Chaos
Back to Chaos website
Contact Support
Sign in Try Buy
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
  1. Chaos Help Center
  2. FAQ
  3. Product Articles
  4. Anima
  5. Anima Software
Can I import my own characters and motions?
Updated November 14, 2025 11:37
Yes. Users are not limited to the content included in Anima.
Using the Anima Designer standalone application in Edit mode, it is easy to import and use 3rd party Posed (static) and Rigged (animable) characters, including motion capture data.
You will find more information about the import process in the following documentation:
  • Import Custom Posed models (Static)
  • Import Custom Rigged models (Animable)
  • Import Custom Motion Clips (Animations)
Was this article helpful?
0 out of 0 found this helpful
Articles in this section
  • What is Anima?
  • Is Anima a Plugin?
  • What content is included in the Anima libray?
  • Is Anima compatible with my 3D software?
  • Can I try Chaos Anima before purchasing it?
  • Anima is crashing on start, how can I fix it?
  • Can I edit or modify the assets from the Anima library?
  • Can I export Anima content to other file formats? (FBX, Alembic, OBJ, 3DS, Collada, etc.)
  • Can I use Anima assets in Lumion, Twinmotion, D5, Blender or other DCC apps not supported by the plugins?
  • Are the Anima 4D models exclusive to 3ds Max users? How can CAD Users (SketchUp / Revit / Rhino / etc) make use of them (i.e. with CAD + Vantage / Envision)?
See more
