Do old versions work with Cloud Licensing? Will they continue to work when I enable Cloud Licensing?
Starting in 2026, only new Chaos product releases will support Cloud Licensing. Earlier versions will continue to use the License Server.
You can run both models side-by-side – for example, keep older versions on a License Server while newer versions use Cloud Licensing.
Updating your product in 2026 will give you the option to use Cloud Licensing or keep your License Server. You will be able to change this setting at any time.
Even when set to Cloud Licensing, the License Server settings are still used by Chaos product versions that do not support Cloud licensing. Cloud-enabled versions will use Cloud Licensing, while older, non-Cloud-enabled versions will use the License Server Configuration.
Was this article helpful?
0 out of 0 found this helpful
