Chaos
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
What are the best render settings?
The default render settings of Corona are generally the best choice in most situations, so there is usually no need to change them. However, some special cases may require additional tweaking of the render settings. There are no "universal" settings that will always provide the best results.
You can follow these simple guidelines which should help in most common cases:
See also:
Was this article helpful?
0 out of 0 found this helpful
