Does Corona support network or distributed rendering?
Yes, it does. You can render over the network using Autodesk Backburner, 3rd paty render managers, or use Corona's integrated DR solution (3ds Max only).
See:
Important note: Corona's native Distributed Rendering should be used mainly in cases where multiple computers are rendering a single image. If you need to render a sequence of frames, where each single computer is rendering a different frame, it is advised to use other network rendering solutions instead, such as Autodesk Backburner or 3rd party render managers.
Was this article helpful?
1 out of 2 found this helpful
