How to Disable All AI Features in Corona - 3ds Max and C4D
Corona includes AI tools, such as the AI Material Generator (which turns images into PBR materials) and the AI Enhancer (which improves the appearance of people and vegetation) and some more.  If you prefer not to use them, you can easily disable all AI features by adjusting a single system setting.
What Gets Disabled
When you disable AI features, the following tools will be turned off or hidden:
  • AI Material Generator – The Chaos Cosmos tool that creates materials from images will be disabled.
  • CMasking_AiEnhancer Render Element – This special render pass will be unavailable.
  • Enhance Button – The AI Enhancer button in the Virtual Frame Buffer (VFB) will be disabled.
  • Enhance for VFB History Images – The AI enhance feature for saved history images will no longer be available.
  • Veras button.
  • Any other AI feature in Corona and all other Chaos products.
Note: disabling AI features disables them for all Chaos products, not just Corona!
How to Disable AI Features
Follow these steps to turn off all AI features:
  1. Open System Properties
    • Press Win + R, type sysdm.cpl , then goto Advanced Tab.
  2. Click Environment Variables…
  3. Under User variables, click New
  4. Add the following variable:
    • Name: CHAOS_DISABLE_GEN_AI
    • Value: 1
  5. Click OK and close all windows
  6. Restart your application (3ds Max or Cinema 4D)
After restarting, the AI Material Generator and Enhance options will be disabled.
To Re-enable AI Features
If you want to bring the AI tools back:
  1. Go to the same Environment Variables window.
  2. Delete the variable CHAOS_DISABLE_GEN_AI or set its value to 0.
  3. Restart your application.
Was this article helpful?
0 out of 1 found this helpful
