Chaos
I get error “Error code -1073741795 - (null)", MSVCD100.dll or similar error message!
I get the error “Error code -1073741795 - (null)" or similar error message when starting my host application (3ds max, cinema 4d,…)
The most common solution for this problem is installing Service Pack 1 for Windows7.
Corona Renderer uses the latest AVX2 instructions which are in the newer processors (e.g. i7-3xxx or i7-4xxx) but there was a bug in these Intel CPUs causing Corona to crash. The bug was subsequently fixed with a microcode update. The fix is available in Windows Update, so you should be able to resolve the problem just by installing the latest Windows updates. If you were not installing updates previously, you will need to install all available updates, restart the computer, and repeat the cycle several times. Each time after rebooting, you will see new updates.
If the problem persists even though you have downloaded all the available Windows updates, please download this file:
http://www.microsoft.com/en-us/download/details.aspx?id=40784
Install it, restart your PC, and then check if there are any new Windows updates available on the list.
Similar error. Installing the newest Windows Updates should fix the problem:
Was this article helpful?
0 out of 1 found this helpful
