Chaos
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
What is CTexmap render element in Corona for 3ds Max?
The CTexmap render element lets you render a pass with a chosen texture map applied to the whole scene (except excluded objects). You can use it to add ambient occlusion or other texture passes for further post-processing.
This pass does not include any shading information. It can use a custom background color (which is sometimes required when compositing the beauty and CTexmap elements), and can be denoised
Examples
1. The beauty pass:
2. Ambient occlusion map (CoronaAO) used in the CTexmap render element:
Result:
3. The result of compositing the Beauty and CTexmap elements (using "multiply" blending mode in Photoshop):
4. A Checker map used in the CTexmap render element:
5. A procedural noise texture used in the CTexmap render element:
See also:
Was this article helpful?
0 out of 0 found this helpful
