Corona 8 - Chaos License Server Basic Troubleshooting Steps
If you experience any difficulties in activating your license, these basic troubleshooting steps should resolve it for you.
Note: this article applies only to Corona 8 and newer. For Corona 7 and older, see:
- Activating Corona Renderer 7 (and older) for 3ds Max
- Activating Corona Renderer 7 (and older) for Cinema 4D
Step 1 - Check that the Chaos License Server is properly installed and that you are signed in
Normally, the Chaos License Server, which is required to activate Corona, should be automatically installed together with Corona. To check if it’s installed correctly, open your web browser and enter the following address: http://localhost:30304/
If the Chaos License Server is installed correctly, you will see a website titled “License Server” with either your current license and account information, or an option to sign in:
The Chaos License Server window - if you are already signed in
The Chaos License Server window - if you are not signed in |
If you are unable to access the Chaos License Server (either it does not load at all, or it shows an error message), please follow the below steps:
Step 2 - Reinstall the Chaos License Server by running the Corona installer
Windows:
Run the Corona installer and select the “Custom” installation mode:
Press Next and make sure that the License Server item is selected:
Press Install to finish the installation process.
macOS:
Run the Corona installer and select "Customise":
Make sure that the Chaos Licensing Server option is enabled:
Step 3 - Check if the Chaos License Server is now installed correctly
After the successful installation, open your web browser and enter the address http://localhost:30304/
If you are still unable to access the Chaos License Server at this point, please contact us.
If you are able to access the Chaos License Server:
- If it is showing your account name and the available products - the issue is now resolved and you can start using Corona.
- If it is showing the “Sign in” option - please sign in with your Chaos account. You should then see your account name and the available products, and then you can start using Corona.
Step 4 - If you are still unable to activate your license
This applies, for example, if you can access the Chaos License Server at http://localhost:30304/ and you can see your licenses in it, but for some reason, the license does not get activated in the host software and you cannot use Corona:
Windows:
- Go to the Windows "Add or remove programs" list, search for the Chaos License Server application and uninstall it.
- Remove any remaining files from the following folder:
C:\Program Files\Common Files\ChaosGroup\ssl - Download and install the newest Chaos License Server:
https://download.chaos.com/?platform=47&product=48 - Go to your Chaos License Server ( http://localhost:30304/ ), sign in, and check if you can see your licenses there and if you are able to activate your licenses in the host software now.
If you are still experiencing some issues at this point, please send us:
1) A screenshot showing what exactly you see at http://localhost:30304/
2) A screenshot of any additional error/notification you see
macOS:
1. Go to ~Applications/ChaosGroup/VRLService/OLS/uninstall/ folder and open the "Uninstall" tool and complete the process until the License Server is completely uninstalled. (close any terminal window that remains open)
2. Remove any remaining files from the following folder:
/Users/<userName>/.ChaosGroup/ssl/
Note 1: Since the mentioned folder is not visible, please use the "Go to Folder..." option from the menu "Go" in Finder, then copy & paste the folder path and click on the Go button.
Note 2: Please replace the <userName> text with your current user name registered on your mac.
3. Download and install the newest Chaos License Server:
Note 3: If you can't open the installer by double-clicking on it, simply right-click on it and choose the "open" option, then confirm the permission to open the app.
4. Once installed, go to your Chaos License Server ( http://127.0.0.1:30304/ ), sign in, and check if you can see your licenses there and if you are able to activate your licenses in the host software now.
1) A screenshot showing what exactly you see at http://127.0.0.1:30304/
For further information about the Chaos License Server and its advanced options, see Chaos License Server - Advanced usage.
If you need any further help - please contact us.
