I can't see the Corona VFB, it disappeared and I am unable to bring it back!
This solution applies in case the Corona VFB has disappeared for you and you are unable to bring it back.  We are working on preventing this issue from happening, but you can already try the following workaround:
  1. If you are rendering anything, stop rendering.
  2. Press F9 to start rendering again. At this point, do not touch anything, do not click any buttons, do not stop or cancel the rendering.
  3. Press Left Alt + Space on your keyboard, then press the M key, then press any Arrow key (for example Left Arrow key), then move your mouse cursor to your main monitor.
  4. At this point, the VFB window should appear and it should "stick" to the mouse cursor.
 Alternatively, in point 3 instead of using the Alt+Space combination, you can press the Windows key + any Arrow key. This will move the VFB window to various positions on your monitor.
The most important thing is to start the rendering process (F9) and only then execute the commands.
If you are unable to see the Corona VFB after performing the above steps, please contact us and we will do our best to help you.
Was this article helpful?
0 out of 0 found this helpful
