Systems/backend changes
Enscape 4.1 is now part of the Chaos account and licensing system. In order to be able to use the Enscape account you will need unrestricted internet access to the following addresses:
The port number should be set to listen on port ‘443‘ with the protocol being set to TCP (http and https).
Was this article helpful?
1 out of 19 found this helpful
