How to save V-Ray Proxy Tutorial as .vrmat files
This artcle covers an alternative workflow for saving V-Ray Proxy Mesh as .vrmat files, as well as creating a custom library of proxies.
Note: The process is nearly identical for both SketchUp and Rhino.
Workflow
  1. Convert objects into a Proxy Mesh, using one of the following UI paths:
  • Extensions > V-Ray > V-Ray Objects > Export Proxy
  • V-Ray Objects Toolbar > Proxy buttons > Export Proxy
  1. Save the Proxy Mesh as a .vrmat file by going to V-Ray Asset Editor > Geometries > Right-click on the Proxy Mesh > Save As.
  2. To utilize an already existing .vrmat proxy file from your library, load it through the V-Ray Asset Editor: V-Ray Asset Editor > Import Asset File and click on the folder icon at the bottom of the V-Ray Asset Editor.
Note: In SketchUp, the proxy file imports into SketchUp's Components menu and can be accessed from there.
See also: Here is a tutorial that shows how to create a custom library of proxies that are easily accessed through the V-Ray Asset Editor's Library window (left rollout window):
Was this article helpful?
0 out of 0 found this helpful
