What are the additional components which Corona needs to work and how to install them?
What are the additional components?
The additional components include Microsoft Visual C++ Redistributable Packages and .NET Framework. These components come as small standalone installers or Windows Update packages and they are provided by Microsoft for free.
Do I need to install those components manually?
No. By default, our installer will install all the required components automatically. You may however need to install them manually in some situations, such as using the "unpack files" option in the installer, or if the automatic installation fails for some reason.
Where to download them?
You can find the newest version of Microsoft Visual C++ Redistributables here:
Note: always download the x64 version!
https://learn.microsoft.com/en-US/cpp/windows/latest-supported-vc-redist?view=msvc-170
You can find the newest version of .NET Framework here:
https://dotnet.microsoft.com/en-us/download/dotnet-framework
Which version to use?
Always download the newest x64 version of Microsoft Visual C++ Redistributable and the newest version of .NET Framework available on the Microsoft website.
Is there a silent mode for MSVC++ installation?
Yes. Run the installer from Elevated Command Prompt (type "cmd" into the Windows search, right-click on "Command Prompt", select "Run as Administrator") and use the following switches: /install /quiet /norestart
In case of troubles with locating or installing the required files, please contact us.
Was this article helpful?
0 out of 0 found this helpful
