Chaos
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
Installer says that there were errors during the installation process
You will see a list of files that could not be copied. This can happen for several reasons, including:
  • Your 3ds Max or Cinema 4D process is running - you need to close all 3ds Max or Cinema 4D instances before installing Corona.
  • You are trying to install Corona in a non-existent directory.
For general information on installing Corona, also see: Installation process. (3ds Max | C4D)
Was this article helpful?
0 out of 13 found this helpful
