Chaos
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
Node(s) fail and I am getting "Error rendering frame 0: DLL <C:\Program Files\Autodesk\3ds Max 2015\stdplugs\_plugin name_.dlm> failed to initialize." in MaxLog
Description
This message found in the MaxLog in Corona's DR installation/DrData folder means that 3ds Max was unable to initialize one of its standard plugins, and therefore the distributed rendering was terminated.
Solution
Currently, the most reliable solution is to re-install 3ds Max on the node where the problem appears.
Examples
Error rendering frame 0: DLL <C:\Program Files\Autodesk\3ds Max 2015\stdplugs\CreaseMod.dlm> failed to initialize
Was this article helpful?
0 out of 2 found this helpful
