Rays per second too low
There are several measures of rendering performance other than “how long do I need to wait for the noise to go away”, that can be used for performance debugging, (i.e. determining why a scene is taking too long to render). One of them is "rays per second" displayed in the render stamp and/or in the “Stats” panel of the Corona VFB.
Rays per second is the basic measure of the renderer's raw, brute force performance. It is the number of all rays traced per second in the renderer. Corona running on a single i7 CPU can usually cast 1 500 000 - 4 000 000 rays/s, depending on the scene complexity.
Low rays/s indicate that the renderer lacks the brute force performance needed to efficiently render the scene. Reasons for low rays/s number include:
Old/slow CPU, running other intensive tasks in the background, not running on all available CPU cores
Complex geometric models
Complex texture/material setup
Massive use of instancing
Non-rigid (deformation) motion blur
GI vs. AA balance value set too low (e.g. 1 or 2)
Too many opacity-mapped objects
If you have too low rays/s in your scene, you can try to:
- Convert standard bitmaps to Corona Bitmap
Disable/reduce bitmap filtering
Simplify complex shader networks in Node editor
Fake motion blur in post-production
Increase GI vs. AA balance to at least 4
Replace opacity-mapped objects (like leaves) with geometry
