I am getting BSODs (Blue Screens Of Death)!
User software running on modern operating systems such as Windows 7/8/10/11 cannot cause BSODs. BSODs are usually caused by corrupted Windows installation, faulty drivers, or hardware instability.
While Corona cannot cause BSODs directly, it can trigger a BSOD indirectly by stressing the hardware which might be unstable under load. Corona can cause more BSODs than other software because during rendering it is heavily stressing all CPU cores (as well as RAM, to a lesser extent) for prolonged periods of time, and tries to use all CPU execution units as much as possible.
If you are frequently getting BSODs, try running stability/performance tests to see if your system has any problems.
External links
Guides:
How to Fix the Blue Screen of Death on Windows - WikiHow
Windows BSOD analysis - A thorough usage guide - Dedoimedo
Useful tools:
Memtest - memory test
Prime95 - CPU stress test
HWMonitor - monitor various parameters of hardware
SpeedFan - monitor voltages, fan speeds, temperatures, and more
CoreTemp - compact temperature monitoring application
Was this article helpful?
0 out of 0 found this helpful
