Chaos
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
Rendering has low quality! (looks blurry, pixelated)
If your rendered image has an unexpectedly low quality, for example it looks blurry, pixelated, or low-resolution, please check the following options:
1) NVIDIA AI Denoising
Solutions:
Disable NVIDIA AI Denoising completely.
Note: it has to be disable in two places to disable it for interactive and production rendering:
  • Production rendering: Render Setup > Scene > Denoising > Mode (set to "None" or some other denoising type)
  • Interactive rendering: Render Setup > Performance > Interactive rendering > "Fast preview denoise during render" checkbox (disable it)
2) Image upscaling factor
Solution:
You can disable the image upscaling factor in Render Setup > System > System settings (set it to 1.0):
See: What is Image upscaling factor?
3) NVIDIA AI Upscaling
Solution:
Disable the NVIDIA AI Upscaling for production and interactive rendering:
  • Production rendering: go to Render Setup > Scene > Production Upscaling and make sure "Mode" is set to "Disabled".
  • Interactive rendering: go to Render Setup > Performance > Interactive Rendering and make sure the checkbox "Upscaling" is disabled.
If the above solutions did not help, please contact us about your issue.
Was this article helpful?
0 out of 6 found this helpful
