Can I use a single license on more than one machine?
Yes, unless you own a Solo license which is a fixed-seat license, meaning it is locked to a single machine.
Our other Chaos products use a floating license system that allows users to use their license on different machines as long as they have downloaded the correct build, installed a license server, and logged in with the email address linked to the license.
For example, if you have one active Chaos Premium license, you can use it on multiple machines, but not simultaneously. You need to stop using the product on the first machine before activating it on the second one. Closing the host application will release the Chaos license immediately.
If you have two active Chaos Premium licenses, you will be able to use them on two machines at the same time.
You can install the Chaos license server on any machine you like - workstation, server, laptop, or anything else. The server will distribute all the available licenses.
To get more details on the topic, please check our License Setup page in the documentation portal.
Was this article helpful?
32 out of 58 found this helpful
