How to fix "Cannot connect to Chaos Services"
If you are seeing connection errors like:
  • Please check your internet connection, VPN, or firewall settings, then try again.
  • It seems that your network proxy is blocking the connection.
This means that your product cannot connect to Chaos to obtain a license. The most likely cause is a firewall, proxy or other security software is blocking the connection.
Error codes: -89, -90
Firewall allowlist
In your firewall or security software, allow access to the following:
  • *.chaos.com (including accounts.chaos.com, api.chaos.com, ols.chaos.com)
  • *.chaosgroup.com
  • *.enscape3d.com
Proxy configuration
Chaos Licensing can auto-detect PAC files or use a manual proxy configuration. You can change the proxy settings by editing the following config file:
  • Windows: %LOCALAPPDATA%\Chaos\UnifiedLogin\config.json
  • macOS: ~/Library/Application Support/Chaos/UnifiedLogin/config.json
  • Linux: ~/.config/Chaos/UnifiedLogin/config.json
A) Auto-configuration (recommended first)
If you use a proxy, enable auto-configuration to pick up the PAC file. The following settings can be used to detect PAC/WPAD automatically.
  "proxy": {
    "enabled": true,
    "url": ""
B) Manual proxy URL
If auto-config fails, try to set a full proxy URL (scheme, credentials, host, port) in config.json. Use the full URI format, for example:
  "proxy": {
    "enabled": true,
    "url": "http://username:password@proxy.company.com:8080"
Notes:
  • Include the scheme (http:// or https://).
  • Percent-encode special characters in usernames/passwords.
  • If your proxy uses OS credentials, you can omit username:password@ and rely on system auth.
C) No proxy
If you do not use a proxy, turn off proxy configuration:
  "proxy": {
    "enabled": false
After editing config.json:
Quit and reopen the Chaos Login app (or restart the machine) to apply changes.
  • If you see 407 Proxy Authentication Required, sign in to the proxy or update proxy credentials.
Still blocked?
Open a ticket to Chaos Support: https://support.chaos.com/hc/en-us/requests/new
  1. Collect any relevant logs or screenshots. The log files can be found in the following directories:
    • Windows
      • %LOCALAPPDATA%\Chaos\UnifiedLogin\logs\
      • %LOCALAPPDATA%\Chaos\licensing-client\log\
      • %APPDATA%\Chaos\VRLService\logs\
    • macOS
      • ~/.Chaos/UnifiedLogin/logs/
      • ~/.Chaos/licensing-client/log/
      • ~/.ChaosGroup/logs/
    • Linux
      • ~/.Chaos/VRLService/logs/
  2. Contact Chaos Support with:
    • A short description of what you’ve already tried
    • Your Chaos product and version
Related links
Was this article helpful?
2 out of 7 found this helpful
