How many licenses do I need?
You need one workstation license for each person who will use a Chaos product at the same time, and you can add render node licenses for each additional machine you want to use for rendering to speed up performance.
Determine the number of workstation licenses
You need one workstation license per simultaneous user.
  1. Count how many employees will use the Chaos product at the same time.
  2. Purchase that number of workstation licenses.
Example: If 10 employees will simultaneously work on a project that requires a Chaos product, you need 10 workstation licenses.
Add render node licenses to speed up rendering
To reduce render time, add one render node license for each additional render machine you plan to use.
  1. Decide how many extra machines will render alongside the workstation.
  2. Acquire that number of render node licenses to utilize those machines.
Get personalized guidance
If you want recommendations tailored to your setup, contact Chaos Support or work with your preferred local Chaos reseller.
Was this article helpful?
1 out of 9 found this helpful
