I am unable to sign in even after trying all the available solutions
  • No Active Chaos Envision License:
If you encounter the error "No active Chaos Envision license", it means that no valid license is currently associated with your Chaos account. This can prevent the application from launching.
If you are unable to activate a free trial or purchase a license, the only way to bypass the authentication issue is to sign in with a different Chaos account that has a valid license. This must be done through the Chaos License Server to successfully launch the application.
  • Unable to obtain Chaos Envision license -197: There are no available licenses of this type on the Chaos License Server. The application will now terminate.
This error appears when the currently signed-in Chaos account has no valid or available Envision licenses on the License Server. As a result, the application cannot start and closes automatically. To proceed, you have to sign in with an account that has an active Chaos Envision license.
  • Chaos Unified Login is not running. Please start Chaos Unified Login application and try again.
This error indicates that the Chaos Unified Login (ula.exe) service is not active. The application requires this service to authenticate the user and validate licenses. To resolve the issue, you have manually launch the Chaos Unified Login application by typing "Start Chaos Unified Login" in the Windows Start Menu and retry.
  • Unable to obtain Chaos Envision license: 10061: The Chaos License Server could not be reached (refused connection). The application will now terminate.
This error occurs when the Chaos License Server is not running or cannot be reached, even though other services like Chaos Unified Login and Cosmos Browser are active. To fix this, you have to ensure that the License Server application is running and properly connected. You may need to terminate the Chaos License Server process  in the Windows Task Manager - terminate vrlsupervisor.exe first and then vrol.exe. Then start the Chaos License Server process manually by typing "Start Chaos License Server" in the Windows Start Menu.
Was this article helpful?
1 out of 12 found this helpful
