When the frames per second value is not limited, Envision renders as many frames as possible based on the hardware capabilities and this may cause framerate fluctuations. To improve FPS stability, pick a fixed FPS value in the Resolution & display control window and additionally navigate to File menu > Project Settings and make sure that the VSync (Vertical Synchronization) option is enabled. If the issue persists, contact the Chaos Support team.
