Critical Error when launching Envision - The current system hardware configuration doesn't meet the minimum requirements
Error Message: Critical Error - The current system hardware configuration doesn't meet the minimum requirements for the application to launch, the application will now terminate.
There are two possible causes for this message to appear:
  • Your hardware does not meet the minimum requirements to run the application. In this case, double check Envision's minimum requirements and verify if your hardware is indeed not compatible with Envision.
  • Your hardware meets or exceeds the minimum requirements, but the error still occurs. In this case, make sure your GPU drivers are properly updated to the latest version (avoid using Beta driver versions). Verify that your display adapters are properly validated, updated, and enabled in the Device Manager. Also, check that the correct GPU is selected for running the application in the Device Manager.
If the issue persists, contact the Chaos Support team.
Was this article helpful?
1 out of 1 found this helpful
