This article compares V-Ray (CPU) and V-Ray GPU so you can choose the best render engine for your project.
In this article you can find answers to questions such as:
- Which render engine is faster - V-Ray or V-Ray GPU?
- What are the similarities and differences between V-Ray and V-Ray GPU?
- How V-Ray and V-Ray GPU utilize hardware?
Understand the difference between V-Ray and V-Ray GPU
Let us start by clarifying that the CPU version of the V-Ray renderer is simply called “V-Ray”, while the GPU version is called “V-Ray GPU”.
It is common to think that V-Ray and V-Ray GPU are the same render engine and the only difference is the hardware they run on. The way that CPU and GPU devices operate, however, is completely different. Both have their advantages and disadvantages when performing certain types of computations.
Developing software that runs on both types of devices requires approaching the code for each device differently to maximize performance and efficiency.
That being said, the correct statement is that V-Ray and V-Ray GPU are completely different render engines.
Hardware Utilization
- V-Ray
Rendering with V-Ray uses the CPU device. Features like the V-Ray Denoiser and the V-Ray Lens Effects can utilize the GPU independently of the renderer, as they are applied as a separate post-process. To render on a CPU, your PC should meet the minimum System Requirements.
- V-Ray GPU
V-Ray GPU takes advantage of the graphics card, but it relies on the CPU to feed it with tasks. This means that CPU performance also impacts GPU rendering.
Take a look at the V-Ray GPU Setup page for more information regarding supported devices in V-Ray for 3ds Max. Supported devices information is available for all V-Ray integrations on their respective GPU pages.
- Hybrid rendering (CPU + GPU)
Hybrid rendering is a mode of the V-Ray GPU engine that utilizes both the CPU and GPU devices. This way, the rendering performance benefits from all the available hardware on your workstation.
For additional information on how V-Ray utilizes computer hardware, check the Hardware Recommendations article and the Understanding V-Ray Hybrid Rendering article.
Performance
The advancement of GPU hardware increases performance at a lesser cost. This makes V-Ray GPU increasingly popular.
The more popular it becomes, the more users test the performance of the two V-Ray engines by simply switching from one engine to the other with the same scene and comparing the results. This approach is inaccurate. The two engines work differently and execute differently.
Therefore, it is recommended to use scenes that are optimized for the specific renderer. Some scenes are expected to render faster with GPUs compared to the CPU, while others will show comparable performance results.
V-Ray typically starts rendering faster, while V-Ray GPU often compensates with higher throughput as the render progresses. So you can expect shorter initial startup with V-Ray, but potentially faster overall completion with V-Ray GPU, depending on the scene and hardware. For example, the V-Ray GPU engine utilizes the RT Cores in NVIDIA RTX GPUs (Turing architecture and later), which accelerate the ray-tracing calculations and can speed up the rendering by an average of 40%.
Faster Feedback, Faster Decisions
With the performance gain in V-Ray GPU, you can expect to receive faster feedback from a project.
This allows you to make more decisions and be more creative while iterating for the same amount of time. This performance advantage also indirectly affects your overall rendering quality since more time is spent on creative choices, instead of rendering.
Measure your hardware with V-Ray Benchmark
Chaos offers V-Ray Benchmark - a performance measurement tool that assesses the hardware's speed specifically when working with V-Ray. The benchmark includes two test scenes: one for V-Ray and another one for V-Ray GPU. It can quickly and easily evaluate a user’s machine capabilities when running V-Ray and V-Ray GPU. The results can be compared with other users' data and help when looking at specific hardware.
Use features that improve performance
A huge advantage of V-Ray GPU is that it utilizes multiple graphic cards installed on a single machine. Setting up additional GPUs is effortless and their pricing is reasonable, in contrast with CPUs installed on a multi-socket motherboard. This also scales the performance almost linearly with GPUs. For example, with two identical GPUs, a user may expect to see the render times to be twice as fast, compared to a single GPU.
The V-Ray engine runs on NUMA configurations (dual CPU machine). However, this may require a substantial upgrade to the whole PC. In contrast, a second GPU can be effortlessly added if your motherboard has compatible PCI slots.
Both render engines benefit from the latest features for performance improvements like Adaptive Lights and the Adaptive Dome Light.
Supported Features
V-Ray currently includes a broader set of features than V-Ray GPU because the engines are built on different codebases.
However, it’s important to outline that the GPU renderer is fully production-ready and includes all required features for professional production work. Moreover, V-Ray GPU receives new features with each release, continually closing the gap with the V-Ray engine.
Check the list of V-Ray GPU for 3ds Max supported features (see the respective page for other V-Ray integrations).
Memory
A major difference when comparing V-Ray and V-Ray GPU is the utilized memory. V-Ray makes use of the CPU memory (RAM), while V-Ray GPU utilizes the GPU memory (VRAM).
Common workstation configurations today have 32, 64 or 132 GBs of RAM. At the same time, a common graphics card used for GPU rendering has 8 or 16 GBs of VRAM.
When using the CPU and RAM, it is possible to add more memory, given a free slot is available on the workstation's motherboard.
You can also attach an additional unit to your GPU(s). However, this does not automatically mean doubling the cards combined VRAM. Only High-end NVIDIA GPUs offer this capability with a feature called NVlink that allows bridging the memory of 2 identical graphics cards.
V-Ray GPU supports NVlink connections, which allows almost doubling the amount of GPU memory on a workstation. The latest version of V-Ray comes with an initial implementation of out-of-core rendering. It transfers triangle meshes to the CPU memory when the GPU runs out of memory, allowing to render scenes with a lot of geometry.
More in-depth information can be found in the Hardware Recommendations article.
Network Rendering and Chaos Cloud
V-Ray and V-Ray GPU are both available for network rendering using Backburner, Deadline, and other render managers.
V-Ray comes with its own Distributed Rendering feature that allows splitting a single render job within a single frame across many computers in a network. See the Distributed Rendering page in V-Ray for 3ds Max or the respective page for other V-Ray integrations.
Chaos Cloud is Chaos's proprietary rendering service and it supports both V-Ray and V-Ray GPU.
Conclusion: key differences
The main differences are in hardware use, feature coverage, memory limits, and interactivity.
- Hardware: V-Ray uses the CPU; V-Ray GPU uses one or more GPUs and can run in hybrid mode with the CPU.
- Performance scaling: V-Ray scales with CPU cores and clock speed; V-Ray GPU scales with the number and performance of GPUs.
- Feature coverage: V-Ray includes the full feature set; V-Ray GPU supports most common features, but some features may be unavailable or behave differently.
- Memory: V-Ray uses system RAM; V-Ray GPU uses GPU VRAM, which can limit scene size depending on available VRAM.
- Interactivity: V-Ray GPU typically provides faster interactive rendering for look development.
- Image parity: Both engines aim for similar results, but renders can differ due to engine-specific implementations and difference in the supported features.
