Chaos
Back to Chaos website
Contact Support
Sign in Try Buy
Keep Enscape running smoothly. Switch to the latest version in 3 simple steps. [Update Now]
  1. Chaos Help Center
  2. FAQ
  3. Product Articles
  4. Corona
  5. Corona for 3ds Max
  6. Distributed Rendering Troubleshooting
Could not start 3ds Max X. Autodesk Backburner is required for Corona distributed rendering, but it doesn't seem to be installed.
Updated May 17, 2023 10:57
This message is shown if Autodesk Backburner installation is not detected on the node. Autodesk Backburner is not directly used in Corona distributed rendering, but it is required in the process. Please refer to the following guide: How to use distributed rendering?
Was this article helpful?
1 out of 1 found this helpful
Articles in this section
  • Troubleshooting Backburner Error 109 in Corona for 3ds Max
  • DR is not working and I am getting "Cannot bind to the remote connection port (TCP 19666)" error!
  • Distributed Rendering is working with computer A as master and computer B as render node, but not the other way around!
  • Distributed Rendering does not work - "Unknown error while loading application"
  • My render nodes are not visible on the list after pressing "Search LAN"
  • I can see dark / bright strips in my rendering
  • I am getting "Closed Loopback Connection" message and DR is not working
  • Gathering DR Logs
  • Some of the render nodes are working fine, but some are not!
  • Distributed Rendering stopped working after the installation of newer version
See more
