Phoenix Particle Shader - Known bugs and limitations
This guide lists currently known bugs and limitations when rendering the Phoenix Particle Shader.
- Rendering Phoenix Particle Shader is not possible with Corona 5 or older. Phoenix Particle Shader support has been introduced in Corona 6.
- The minimum supported version of Phoenix is 4.10.02.
- The Cutter Geometry feature is not currently supported in Corona, users can still achieve similar results by utilizing the Corona Slicer Material. This feature allows users to define a material that cuts through geometry, providing a workaround solution for situations where the Cutter Geometry feature cannot be used.
- The Environment feature is currently not supported. We may add it in the future.
