How to uninstall V-Ray Swarm
V-Ray Swarm is Chaos Group’s distributed rendering manager. It is often installed alongside V-Ray for SketchUp, Rhino, Revit, or as a standalone component on render nodes. Uninstalling the main V-Ray plugin does not automatically remove V-Ray Swarm - you must uninstall it separately.
Uninstall V-Ray Swarm on Windows:
  1. Close SketchUp, Rhino, Revit, or any other host application that uses V-Ray.
  2. Open Settings → Apps → Installed apps (on Windows 10 this is Apps & features).
    Alternatively, use Control Panel → Programs and Features.
  3. Locate V-Ray Swarm (or V-Ray Swarm 2) in the list.
  4. Select it and choose Uninstall.
  5. Follow the on-screen prompts to complete the process.
You can also run the uninstaller directly if it is present, typically at a path such as:
  • C:\Program Files\Chaos Group\V-Ray Swarm\uninstall\installer.exe
  • C:\Program Files\Chaos Group\V-Ray\Swarm 1.4\uninstall\installer.exe
  • C:\Program Files\Chaos\V-Ray\Swarm 2\uninstall\installer.exe
(Exact path depends on the installed version.)
Uninstall V-Ray Swarm on macOS
macOS
  1. Quit SketchUp (or the relevant host application).
  2. Open Finder and navigate to the uninstaller:
    • Recent versions: /Applications/Chaos/V-Ray/V-Ray for SketchUp/uninstall
    • Older versions (pre-V-Ray 7): /Applications/ChaosGroup/V-Ray/V-Ray for SketchUp/uninstall
  3. Double-click Uninstaller.app.
  4. In the uninstaller, check only the V-Ray Swarm option. Uncheck V-Ray itself and any other components you want to keep.
  5. Follow the on-screen instructions to finish.
Was this article helpful?
0 out of 0 found this helpful
