Why do I have light showing up in corners or wall edges?
Light leakage, or light bleeding, is a difficult issue to address in relation to real-time rendering. Here are some steps you can take to improve the behavior:
  • Increase the thickness of the corresponding geometry, and make sure that all of your walls and ceilings have a thickness in general and intersect at the corners
  • Create a second non-transparent wall behind the affected wall • Reduce the size of the ground plane in your project, if it is very large
  • Reduce the amount of clouds being used, as more clouds scattering the light may lead to more light bleeding
  • Use Enscape's Skybox feature, which has the same effect as reducing the amount of clouds in your project
  • Review our Forum article on the topic for more tips
Unfortunately, none of these suggestions will help you to remove this behavior completely, but they can help improve it.
Was this article helpful?
0 out of 0 found this helpful
