This article explains the warning and error messages related to Corona's atmospheric effects - including Sky, Sun, Moon, Stars, Volume, and Clouds - and provides steps to resolve them.
For Corona's atmospheric features to work correctly, the directory C:\Program Files\Chaos\Corona\prgSkyModel must exist and contain the expected datasets.
If these files are missing, corrupted, or left over from an older Corona version, Corona detects the issue at render time, displays a warning message, and automatically falls back to legacy behavior or disables the affected feature so your render can continue without crashing.
Missing Data Error Messages
The following errors occur when required files are missing from C:\Program Files\Chaos\Corona\prgSkyModel (typically due to an incomplete installation, a manual/network deployment where the folder was omitted, or antivirus software blocking the files).
1. 'PRG Clear Sky' model was selected, however the required data is missing. Switching to 'Hosek & Wilkie' model for now.
- Explanation: The PRG Clear Sky model is selected in your Corona Sky map or shader, but Corona cannot locate its dataset in C:\Program Files\Chaos\Corona\prgSkyModel. To avoid failing the render, Corona temporarily switches to the older Hosek & Wilkie sky model.
Solution: Re-run the Corona installer using the standard installation mode to restore the missing prgSkyModel files. If you use a custom or network setup, run the installer with the Unpack option and copy <unpacked directory>\Corona\prgSkyModel into C:\Program Files\Chaos\Corona\prgSkyModel.
2. Stars were enabled, however the required data is missing, disabling stars.
Explanation: Stars are enabled in your Corona Sky settings, but the star dataset is missing from C:\Program Files\Chaos\Corona\prgSkyModel. Corona automatically disables stars for the render.
Solution: Repair your installation by re-running the Corona installer, or extract the installer using the Unpack option and copy the prgSkyModel folder to C:\Program Files\Chaos\Corona\prgSkyModel.
3. Sky volume effect was enabled, however the required data is missing, switching to the legacy effect.
Explanation: The Volume effect (aerial perspective) is enabled in your Corona Sky, but the required volumetric scattering files are missing from C:\Program Files\Chaos\Corona\prgSkyModel. Corona falls back to the legacy aerial perspective calculation instead.
Solution: Re-run the Corona installer to restore the complete prgSkyModel directory, or manually copy it from an unpacked Corona installer into C:\Program Files\Chaos\Corona\prgSkyModel.
4. Clouds were enabled, however the required data is missing, switching off clouds.
- Explanation: Procedural Clouds are enabled in your Corona Sky settings, but the required cloud data files are missing from C:\Program Files\Chaos\Corona\prgSkyModel. Corona disables clouds so the scene can still render.
Solution: Reinstall Corona using the standard installer to restore the missing files, or unpack the installer and copy <unpacked directory>\Corona\prgSkyModel into C:\Program Files\Chaos\Corona\prgSkyModel.
5. Realistic color was selected for the sun, but the required improved model sun data is missing, switching to 'Hosek & Wilkie' model for now.
Explanation: Your Corona Sun is set to Realistic color mode, which relies on the PRG Clear Sky (formerly Improved) sun dataset. Because that data is missing from C:\Program Files\Chaos\Corona\prgSkyModel, Corona falls back to the Hosek & Wilkie color model.
Solution: Run the Corona installer again to restore the missing sun data in C:\Program Files\Chaos\Corona\prgSkyModel, or manually copy the prgSkyModel folder from an unpacked installer.
6. Realistic color was selected for the moon, but the required PRG Clear Sky model moon data is missing, switching to constant color.
Explanation: Your Corona Moon is set to Realistic color mode, which depends on the PRG Clear Sky moon dataset. Since those files are missing from C:\Program Files\Chaos\Corona\prgSkyModel, Corona switches the moon to a Constant color instead.
Solution: Re-run the Corona installer (Corona 12 or newer) to restore the missing moon dataset, or unpack the installer and copy <unpacked directory>\Corona\prgSkyModel into C:\Program Files\Chaos\Corona\prgSkyModel.
Tip: If the files are already present in C:\Program Files\Chaos\Corona\prgSkyModel and these errors persist, verify that your Windows user account has read permissions for the folder and ensure your security software has not quarantined any files inside it.
Outdated Data Error Message
7. "PRG Clear Sky" model was selected, however an old version of the required data is installed. The lowest rendered solar elevation will be limited to -4.2 degrees.
Explanation: Corona 12 introduced an updated PRG Clear Sky model with an extended solar elevation range down to -12 degrees below the horizon (enabling accurate twilight and night sky rendering), whereas earlier versions were limited to -4.2 degrees.
This warning appears when Corona 12 (or newer) loads an older prgSkyModel dataset. In rare cases, this happens if you use multiple host application versions (3ds Max or Cinema 4D) and follow this sequence:
- You install Corona 12 for all host app versions, which installs the new sky model data.
You then install Corona 11 or older for a specific host app version using Custom installation mode, which overwrites C:\Program Files\Chaos\Corona\prgSkyModel with the older data.
When you subsequently launch a host app running Corona 12, it reads the older data. You can safely continue working, though solar elevation will be clamped at -4.2 degrees. (Note: In the opposite scenario - running Corona 11 with Corona 12's newer sky model data - no error message appears and you can work normally, though solar elevation remains limited to -4.2 degrees.)Solutions:- Use multiloaders (3ds Max only): Launch 3ds Max using Corona multiloaders when working with multiple Corona versions. This is the cleanest way to run specific Corona versions without triggering sky model data mismatches.
Install older versions first: Always install older versions of Corona first, and install the newest version last. This ensures the latest prgSkyModel dataset remains in place.
- Manually swap the sky model data: Run the Corona installer and select the Unpack option, which extracts the data to <unpacked directory>\Corona\prgSkyModel. Copy the files for the version you want to use directly into C:\Program Files\Chaos\Corona\prgSkyModel.
