Full error message text:
Parallax mapping is not supported in materials with decals or in Layered materials combining displacement from multiple layers. Regular displacement will be used instead in material(s) '<material names>'.
This error message appears in two unsupported scenarios:
- When parallax displacement is enabled in a material applied to a Corona Decal object ( 3ds Max | Cinema 4D ).
- When parallax displacement is used in a Corona Layered Material ( 3ds Max | Cinema 4D ) where displacement is combined using multiple material layers.
Solutions:
- Disable parallax displacement and switch to classic displacement in any material that is applied to a Decal or used within a Layered Material by disabling the "Parallax mapping only" checkbox:
or
- Do not use displacement at all in the above cases.
